Results 1 to 10 of 13
Thread: Truss Visibility Issues
    2001-01
    81
    Question Truss Visibility Issues
    I am having some trouble with the visibility of my truss family in plan view. I have my Top set to offset 8'-0" Finished Floor Level. I have my Cut Plane set offset to 8'-0" from Finished Floor, Bottom offset -1'-0" from Finished Floor. My View depth is set to offset -1'-0" from Finished Floor. Why is my truss that is 26''-0" above finished floor showing up in plan with my view range set the way I have it?????? See attached files . . . . . . .
    2008-11
    Australia
    467
    Default Re: Truss Visibility Issues
    Quote Originally Posted by tknapp View Post
    Not too sure why it's displaying in this view, however it's pretty easy to hide off.
    In your VG (visibility graphics) settings, scroll down the bottom of the list to "structural trusses" and just untick the box and they wont display in that view.
    Active Member snellem's Avatar
    2005-03
    Lexington, MA
    87
    Check the level that the truss is referenced to.
    Erik Snell
    Factory Worker
    I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
    2001-01
    81
    Quote Originally Posted by karalon10 View Post
    Yeah, I can do that, but my issue is that my model is being linked into the MEP & Arch models, and it will be something that they will have to deal with as well.
    2001-01
    81
    Quote Originally Posted by snellem View Post
    The truss is referencing the Roof Level (126'-0").
    2001-01
    81
    Does anyone have any more ideas for me?
    2006-09
    442
    I would check the location of the analytical lines for your truss. Maybe??? Or check the referenced level for the partical elements Top chords, bottom chords ect.. through the tab key.
    2001-01
    81
    Angry Re: Truss Visibility Issues
    Quote Originally Posted by djn View Post
    Analytical lines appear to be fine, referenced levels appear to be fine, I am just not sure what is going on . . . . .
    I could stop if I wanted to FOUTJM's Avatar
    2005-12
    the island
    235
    can you post a screenshot of your view range settings?
    J Fout
    Artist, Revit Grunt
    "it is not the answer i seek, but to understand the question".
    @scribldogomega
    2005-12
    the island
    235
    probably be good to see the view properties too.
    sometimes slab will show up when the view range is obviously missing them.
    but i havent seen this with trusses.
    we usually have problems with trusses not showing up in plans.
    J Fout
    Artist, Revit Grunt
    @scribldogomega
  1. Mono Truss with LVL Bearing issues
    By Buzter in forum Revit Structure - General
    Last Post: 2010-03-23, 01:45 AM
  2. Truss visibility in 3D
    By cmbyrd77 in forum Revit Structure - General
    Last Post: 2009-07-24, 05:35 PM
  3. Visibility Issues
    By bearden383 in forum Revit MEP - General
    Last Post: 2008-09-17, 09:12 PM
  4. Truss display Issues
    By jrichardson in forum Revit Structure - General
    Last Post: 2006-01-24, 08:56 PM
  5. Visibility Issues
    By rsharp in forum Revit - Rendering
    Last Post: 2005-10-25, 03:32 PM
