Results 1 to 10 of 10
Thread: 3d Dimensioning?
    2008-11
    Marietta, OH
    19
    Unhappy 3d Dimensioning?
    We are in the process of creating formed up views of parts (mostly in solidworks or other programs, but have some in AutoCAD we need to process quickly and dont have the time to redraw...)
    In taking a flat layout in autocad, throw it into an isometric view, and using the 3d OP/Rotate 3D and 'folding' one end up...i can get the view how i want it, but dimensioning isn't cooperating. I can dimension the horizontal dimensions fine, but when i try to dimension vertical, it just stays stuck on the horizontal and gives me a 0.000 dimension...i have tried the F5 flip for isoplanes and my crosshairs also dont seem to be flipping...
    Im not a big autocad 3d user so, this is new and Im sure im missing something simple...any and all help will be greatly appreciated...thank you!
    Adam
    2008-11
    Marietta, OH
    19
    Default Re: 3d Dimensioning?
    Oh, also, this is AutoCAD 2005, havent had it updated here yet...Thanks
    0,0,0 The Origin
    8,570
    Iso planes are only relevant to flat (2d) isometric drawings not isometric views.
    Have you tried dimensioning in paperspace? It should work though maybe not as well as in later versions.
    Alternatively, in modelspace, you should create a suitable UCS parallel to your view plane.
    You could post a sample file here.
    2008-11
    Marietta, OH
    19
    Ok, ill test that out in the morning and if i cant get it to go, ill post a sample of what im trying to work out, thanks!
    6,388
    You have to change the ucs to be coplanar with the face you want to dimension. 2D dims will always be placed at the current elevation for the ucs.
    2008-11
    Marietta, OH
    19
    Thanks guys, i COMPLETELY forgot the Object UCS, ive been out of drawing for several months and it slipped my mind, Thanks!
    2008-11
    Marietta, OH
    19
    Ok, next question...
    My dimensions are coming in on the correct orientation, but they are backwards...some of them i can change the text rotation in properaties 180 degrees and it works but others the numbers are the right direction but are upside down...is there another trick im forgetting to do that?
    Thanks again
    2008-11
    Marietta, OH
    19
    Also, im dimensioning the iso's in paperspace, i set my dim scale in the dimension style modify settings to scale to fit viewport, my arrowheads are scaling but my text isnt, its staying small, thoughts?
    Cairo - no, not Illinois
    5,069
    does the text style you're using have a defined height? that would take precedence over the dimscale
    2008-11
    Marietta, OH
    19
    Brilliant, all of you, lol, funny how much you forget when you dont do alot of this for a year, thanks!!!!!!!
  1. Dual dimensioning with tolerance Dimensioning with punctuation
    Last Post: 2014-10-22, 04:47 PM
  2. Help dimensioning in 3d
    By cadman33619 in forum AutoCAD 3D (2007 and above)
    Last Post: 2013-07-12, 08:07 PM
  3. 3D Dimensioning
    By dankas in forum AutoCAD 3D (2006 or below)
    Last Post: 2010-09-18, 05:19 PM
  4. Dimensioning in PS
    By StephenJ in forum ACA General
    Last Post: 2006-07-13, 04:11 PM
  5. dimensioning in 3d
    By scoe in forum Revit Architecture - General
    Last Post: 2005-08-30, 08:37 PM
