Thread: Dimensions in 3D drawing placed on the XY plane (all dims on one plane)
    2010-04
    3
    Default Dimensions in 3D drawing placed on the XY plane (all dims on one plane)
    Hi,
    I would like to ask a question about dimensions in 3D drawing being placed on one plane. I have a 3D drawing, and when I draw a dimension, it gets placed by the program on the XY plane. The dimensions do not stay along the dimensioned objects. Please, see the attached picture. For example, you draw a line from [1,1,1] to [3,3,3] and then dimension it. The dim line is placed to [1,1,0]-[3,3,0] instead of along the line. Would anyone, please, know why this is happening? Thanks.
    JT
    I could stop if I wanted to Comach's Avatar
    2005-03
    Scotland
    286
    Default Re: Dimensions in 3D drawing placed on the XY plane (all dims on one plane)
    Change the origin of the UCS to align with the line being dimensioned.
    2010-04
    3
    Would I have to do that every time I dimension any line? (Dimensioning worked fine, I was able to dimension any object in any plane, but then something changed, I do not know what, and I am unable to properly dimension since than.)
    How do I change the origin of the UCS? Tx.
    PS: I think it has something to do with system variables because even if I open a new or old drawing, dimensioning works as described in all drawings. Even if I open old drawing with dims in all planes placed correctly, then when I add new dimensions, the new ones get placed on the one plane as described. Which system variables relate to dimensions and how do I access them?
    2010-04
    3
    Unhappy Re: Dimensions in 3D drawing placed on the XY plane (all dims on one plane)
    I have created another sample drawing from a scratch. Please, see the attachment. Weird thing. I am lost.
    2008-10
    Kearneysville, WV
    106
    Quote Originally Posted by xjessie007 View Post
    I work in 3D daily so I keep the ACAD UCS Toolbar open. It's faster for me to click the toolbar icon than having to try and remember all of the obscure commands. Depending on what you are trying to dimension in 3D, you can change the UCS either to Face, Object, or View to get the dimension to work properly (show in vertical and aligned to the object). For example, select the 3D object with a view from the Front. Then select UCS View and you should be able to dimension the line/object on the 'Z' plane instead of the XY plane. Hope this helps.
  1. Sloped Bottom Plane/ Flat Top Plane
    By signalbass in forum Revit Architecture - General
    Last Post: 2010-01-06, 10:34 PM
  2. Out of plane dimensions
    By rtinker in forum AutoCAD General
    Last Post: 2009-01-06, 01:04 PM
  3. Out of plane dimensions
    By rtinker in forum AutoCAD LT - General
    Last Post: 2008-12-29, 09:04 PM
  4. Sweep Profile plane and Orient by plane
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-02-03, 08:00 PM
  5. Mask difference on vertical plane vs. horizontal plane.
    By SkiSouth in forum Revit - Rendering
    Last Post: 2004-04-24, 01:08 PM
