Is there any way you can specify what pipe type is used when you draw a pipe from a connector? As it is right now when I take a pipe off of a connector, I have to look at the type selector to make sure I'm on the correct pipe type. I don't always remember to do this and constantly have to go back and put pipes back on the right type.
I read the help menu and according to that if you have the pipe types set correctly under conversion, it will use the right type only when using the generate layout tool. Well the generate layout tool sucks. Any other way of doing this?
