Thread: Replacing the PGP File
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Replacing the PGP File
    I have just upgraded to Mechanical v2011 from Mechanical v2010.
    How to SAFELY replace the pgp file in v2011 with my customised pgp file in v2010?
    Your helps are much appreciated.
    Houston
    9,188
    Default Re: Replacing the PGP File
    Assuming that you didn't use the migration tools, and that both files are untouched...... copy your custom stuff from the bottom of the 2010 file and paste it into the 2011 file.
    FWIW - We just use the same PGP file every year, so I copy the entire file over. We may update from the new file every 3 or 4 years...), but we don't use any external commands defined in there, and the vast majority of command shortcuts that we use are defined using lisp. In other words, yes I know I may be missing some new items each year, but it's not causing us any harm.
    Lastly, it doesn't matter if you have multiple .pgp files in the support file search path, AutoCAD will load the first one it finds, and only the first one.
    R.K. McSwain | CAD Panacea |
    2006-04
    1,160
    Thanks. I can see your points.
    And I agree with you that would be simple by using the same PGP file every year - this was what I did for the last 5 years.
    But now I think Autodesk may have already added more new command shortcuts to the v2011 since v2005. So thinking of switch to v2011 safely.
    BTW, I personally don't like to use the migration tools. The one click may bring you the things unexpected while you are blinking.
    Houston
    9,188
    Quote Originally Posted by BoKirra View Post
    I agree. I like to know what is going on, not guess at what may happen....
  1. Attribute replacing
    By prasanthbalu in forum AutoLISP
    Last Post: 2011-07-26, 05:17 PM
  2. Replacing attribute values via an excel file
    By jgardner.79905 in forum AutoLISP
    Last Post: 2010-07-28, 12:16 PM
  3. How to go about replacing existing Blocks within a DWG file
    By Robert.Hall in forum AutoCAD General
    Last Post: 2007-01-24, 10:08 AM
  4. Replacing Text
    By masonjur in forum Revit Architecture - General
    Last Post: 2006-08-28, 03:46 PM
  5. Replacing Blocks
    By bwilliams.72594 in forum AutoCAD General
    Last Post: 2005-10-05, 05:52 PM
