Thread: doors/windows cutting sweeps above
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Question doors/windows cutting sweeps above
    We have some variations of compound/stacked walls w/ sweeps built-into the wall style.
    Doors and windows are cutting thru sweeps which are well above the head/opening cut.
    We do not want the door or window to cut anything above it's opening.
    We think this could be related to the "origin" of the profile used for the sweep.
    Any clues?
    Cheers....
    cbc
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: doors/windows cutting sweeps above
    You are exactly right if the origin of the sweep intersects an opening the whole sweep is cut off. so the solution is to move your profile up or down(in the family editor) as far as required for it not to cut. Now typically if you create your profile right at the crosshair(origin), you want to create a head trim profile starting from the cross hairs and going up. and a sill or crown starting at the top and going down. Not you will have to off set these slightly(1/8" or something). So if that is a problem, then just move it up the 1/8" in the profile family.
    Scott D. Brown, AIA
    BECK
  1. 2012: Cutting voids in Masses, Cutting windows and View Range
    By edaviesc380864 in forum Revit - Conceptual Design Tools
    Last Post: 2014-07-17, 12:36 PM
  2. 2012: Cutting Voids in Masses, cutting windows and view range
    By edaviesc380864 in forum Revit - Student Support
    Last Post: 2013-05-15, 02:09 AM
  3. Revit 2010 Doors and Windows are not cutting walls in Navisworks 2010
    By mike.massey in forum NavisWorks - General
    Last Post: 2009-06-05, 07:30 PM
  4. Cutting Sweeps?
    By Fishmonger in forum Revit Architecture - General
    Last Post: 2006-02-04, 03:45 PM
  5. Sweeps/Reveals Wrapping Around Doors/Windows
    By BillyGrey in forum Revit Architecture - General
    Last Post: 2004-07-05, 03:21 AM
