Results 1 to 7 of 7
Thread: Do not undo Zoom?
    2004-12
    3
    Default Do not undo Zoom?
    Hello,
    Is there any way (built-in or hidden option, customizing) to get AutoCAD 2005 and/or AutoCAD 2005 LT NOT to include zoom actions in the Undo list?
    If I'm not sure of a change I'm making, have a careful look at my design at different view angles and zooms and then decide to Undo the change, I have to go through all the different views/zoom factors that I used before I can undo the actual change. This is driving me mad!
    Cheers, Marco
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    564
    Default Re: Do not undo Zoom?
    Not anyway that I know..... It would be cool. I do know the Other cad software does exactly that..
    2015-12
    Arizona
    2,478
    Begin and End might prove to have some value to you.
    2015-12
    Texas
    564
    Quote Originally Posted by mjfarrell
    I see...
    Groups a sequence of actions into a set. After you enter the Begin option, all subsequent actions become part of this set until you use the End option. Entering undo begin while a group is already active ends the current set and begins a new one. UNDO and U treat grouped actions as a single action.
    If you enter undo begin without undo end, using the Number option undoes the specified number of commands but does not back up past the begin point. If you want to go back to before the begin point, you must use the End option, even if the set is empty. The same applies to the U command. A mark placed by the Mark option disappears inside an UNDO group.
    But you will need to think of this beforehand.....
    2003-04
    Chino, CA
    4,756
    I thought transparent zooms weren't included in the undo....hmmmm just tried it and it seems that only part of the trans-zoom is part of undo???
    13,656
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS72167 - Functionality of UNDO command in AutoCAD® 2002 is different from earlier versions
    Have a good one, Mike
    2009-10
    12
    Please everyone vote for the ZOOM/PAN improvement to be added in future releases:
    https://www.augi.com/wish-list/rank/autocad/463137
    And share the link to every user you know!
    Update: The request has reached the Top 30!
    Now please everyone vote inside the Top 30 in order to have the issue corrected in future releases:
    https://www.augi.com/wish-list/vote/autocad
  1. Do not change the zoom/pan when using undo
    Last Post: 2016-11-02, 09:37 AM
  2. Removing Zoom from Undo
    By sjbayer3 in forum AutoCAD Customization
    Last Post: 2016-11-02, 09:35 AM
  3. Zoom and pan undo in AutoCAD 2010
    By gregorio.grasselli in forum AutoCAD Customization
  4. Undo doesn't combine scroll wheel zoom/pan
    By Fraess in forum AutoCAD General
    Last Post: 2012-09-06, 02:53 AM
  5. Replies: 4
    Last Post: 2007-12-03, 02:16 AM
