Results 1 to 7 of 7
Thread: Center object between two lines Autocad 2010
    2009-07
    Default Center object between two lines Autocad 2010
    I have an object (text) between two other objects (lines). I want the text to be centered between the objects. I've googled and googled, searched help, and I cannot figure it out. This is my first time using Autocad 2010. It's for a school project, and I'm trying to add the finishing touches and make it look pretty and professional.
    Here's an example of what I'm trying to do:
    ----------------- centered text ---------------------
    and
    | centered text |
    Thank you so much for your help!
    (unfortunately the forums delete whitespace... so much for that =\ )
    2004-08
    Iron Station, NC
    3,198
    Default Re: Center object between two lines Autocad 2010
    Quote Originally Posted by enrique_ivers View Post
    and
    | centered text |
    congrats on your first post. Have you tried middle center justifying your text and using the Midpoint between Two Points for your location. When you issue the MTP it asks for the first point, then the second, and then places the object at the midpoint between those 2 points.
    2009-07
    Quote Originally Posted by ccowgill View Post
    Hi Ccowgill. Thank you! I came across the MTP or M2P command while googling, but Autocad 2010 didn't like it.
    I'm using normal Autocad, not Architecture or anything like that.
    9,804
    What do you mean it "didn't like it"?
    Start the TEXT command, enter J (for justify), MC (for Middle Center), then when it asks for the middle point of text, enter M2P....
    Are you getting an error there?
    2009-07
    No; that worked! I'm sure that will take care of what I want to do.
    Thank you both for your help. This is literally my first time working with Autocad other than maybe a two hour intro in class. Just finishing up doing a basic construction site plan, and it's definitely been a learning experience.
    Thank you again!
    2003-06
    North Dallas
    168
    Another way to center text on your line is to create dtext with middle justification somewhere on your line. Issue the TRIM command and select the text. Then select the piece of the line running through the text. The line will trim around the text thus creating centered text on a line.
    9,804
    Exclamation Re: Center object between two lines Autocad 2010
    Quote Originally Posted by mvsawyer View Post
    That is a good tip. Thanks.
  1. AutoCAD 2010 Communication Center
    By UKCADOPS in forum AutoCAD General
    Last Post: 2010-09-08, 02:04 PM
  2. AutoCAD Structural Detailing 64 bit 2010 - New Download in Subscription Center!
    By Dariusz.Kwolek in forum AutoCAD Structural Detailing
    Last Post: 2009-12-24, 04:22 AM
  3. AutoCad 2010: No smooth lines?!?
    By fhoffnar in forum AutoCAD General
    Last Post: 2009-04-15, 12:33 PM
  4. Can I Lines and Text Objects to AutoCAD Table Object?
    By harilalmn in forum AutoCAD General
    Last Post: 2008-08-08, 12:44 PM
  5. Replies: 5
    Last Post: 2007-04-13, 12:26 PM
