Results 1 to 10 of 13
Thread: Fascia not mitering
    2006-12
    Big "D"
    3,711
    Default Fascia not mitering
    Why will my fascia not miter at my dutch hip (see attachment)? It miters everywhere else perfectly. Any ideas?
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Default Re: Fascia not mitering
    That's odd. I usually see that happen when the eaves do not align.
    Did you forget to check "extend into core" on one side?
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by Paul Monsef View Post
    I don't have that checked for any of them. Should I?
    The only two it's not working on happen to be offset from the main roof 2' horizontally. Maybe that's messing it up?
    2003-09
    Everett, WA
    351
    Quote Originally Posted by dzatto View Post
    I generally like my roof slopes to start there. but as long as everything is consistant it doesn't matter.
    Could be, All three sides of that hip are offset 2'?
    Can you upload the roof?
    2006-12
    Big "D"
    3,711
    Well, the dutch hip part protrudes out 2' further than the rest of the roof.
    Not sure how to upload just the roof. It's my first Revit project. Still learning. Getting better though! lol
    2003-09
    Everett, WA
    351
    Or idrop.io the file if it's too large to post. I thought deleting everything but the roof in a copy would make the file size easier to deal with.
    2006-12
    Big "D"
    3,711
    Okay, here it is. I had to make a lot of the roofs by sketching one face at a time and joining them. One or two wouldn't join at all. If you happen to have some spare time (HAHA), if you could take a look at how I did the roofs and let me know if i went about it correctly or if there is a better way. I'd really appreciate it. This was my first roof in Revit.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Often, it's better to just make in-place families for that kind of stuff, Thus, you shall have more control.
    2003-09
    Everett, WA
    351
    OK so here's what I think... Certainly not the Law.
    Try to create the roof (as much as possible) using as few lines as possible, splitting into three sections to raise one in order to create a dutch (or flemish) hip is acceptable - but as complicated as your roof is I would not to it that way... You'll get other issues such as fascias not mitering, odd lines where gutters fascias meet etc...
    see the attached. for the one section create the upper hip portion FIRST, then extend the eaves down. I think you were sloping from the bottom and trying to add the hip. This is a little easier to draw & your fascias will look right,
    I'll try to look at the other section a bit later.
    2006-12
    Big "D"
    3,711
    Thanks for taking the time to help me out. I'll check out the files as soon as I can and try what you described. I'm cleaning off my computer so IT can blow it out tomorrow. Clean install of Win 7 and.....dare I say.....Revit! Now I can start doing my day job in Revit (not just my side jobs).
    I'd love your input on how I did my roof and any tips you may have. All of the houses this guy does have complex roofs. He was impressed with how the roof looked, but any info on making it easier for me would be greatly appreciated! No need to make time, though. If you happen to want to check it out, cool. If you don't have time, I completely understand.
  1. mitering 3D solids
    By JSSMSM in forum AutoCAD 3D (2006 or below)
    Last Post: 2020-07-21, 11:38 AM
  2. Roof fascia - "Can't create Fascia"
    By tomm in forum Revit Architecture - General
    Last Post: 2014-05-14, 04:05 PM
  3. Mitering fascia sweeps
    By JTAND in forum Revit - Platform
    Last Post: 2008-08-29, 04:21 PM
  4. Fascia Mitering Problem
    By Dean Camlin in forum Revit Architecture - General
    Last Post: 2004-06-02, 08:48 PM
  5. Fascia Mitering Bug.
    By beegee in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2004-01-29, 02:16 AM
