Thread: Unknown command "EXPLODE"
    100 Club moshira_hassan's Avatar
    2003-01
    125
    Default Unknown command "EXPLODE"
    I suddenly get this messag when using explode command
    "Unknown command "EXPLODE". Press F1 for help."
    when using new file the command works .. but once i close and reopen the file I got the same problrm again ..
    I'm uding ACAD 2010 and windows XP
    Houston
    7,519
    Default Re: Unknown command "EXPLODE"
    Quote Originally Posted by moshira_hassan View Post
    If you type in ._EXPLODE at the command line, does it work? (notice the leading period in front of the command name)
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    Perhaps you have a corrupt profile or workspace.
    Try switching your workspace and/or profile and see if it helps.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    100 Club murrayc.49304's Avatar
    2003-03
    158
    Try this...
    Enter the command REDEFINE and when prompted to enter a command name, enter EXPLODE
  1. "CUI unknown Command" in AutoCAD 2012
    By gfreddog in forum AutoCAD CUI Menus
    Last Post: 2011-09-06, 09:03 PM
  2. 2011: Draw order "unknown command"
    By thebigd1973 in forum AutoCAD General
    Last Post: 2011-06-21, 09:27 PM
  3. AutoCAD Mechanical 2007 - Unknown command "CUI"
    By svanderputten in forum AutoCAD Mechanical - General
    Last Post: 2007-01-16, 04:01 AM
  4. When using the Shortcut menu - Unknown command "AI_DIM_TEXTHOME"
    By Shane.Miller in forum AutoCAD General
    Last Post: 2006-12-09, 07:17 PM
  5. Replies: 4
    Last Post: 2006-02-03, 06:34 PM
