Can someone please explain the term:
positive 0
Thanks in advance!
positive 0
Thanks in advance!
I haven't seen that before. If you posted the code causing the error that might help us.
R. Robert Bell
Design Technology Manager
Stantec
(rtos(setq tex 2.0)2 2) only returns 2 on my system, so you cant get a substring of "2" starting at the -3 character.
If you want to use this function, I would suggest adding a check that the string length is longer than 4.
Code:(if (>= 4 (strlen tex)) (setq tex (substr tex (- (strlen tex) 4))) )
currently set to not display leading or trailing zeros (12) that is good information to help me out with some of my programs. That also leaves a valid point for the OP's question, a check should be made ahead of time to make sure that zeros are not suppressed on a users system when the command is run.
