Today I was putting in a dimension string and notice something I didn't think was possible in Revit. And now I'm questioning how accurate Revit really is? Project uints and Dim type units set to 1/256" I place a dim string from col center to face of opening to face of opening to col center. I then placed a dim string from col center to col center (which resulted in a 45'-0" dim). The string that went to the openings didn't match the over string when you added them up. It was off by 1/256" So I adjusted the slab edge slightly to and set it to a real number. The only way I'm thinking the results I got are possible would be if I was somehow right in the middle of a 1/256".
So here's the question.
I believe with autocad, they run out precision to 14 decimal places regardless of what you have your units set to. I'm wondering if the same is true with Revit?
Anyone know?
