We are having trouble getting halftone lines to plot correctly from Revit MEP 2010. The problem is specific to the linked model. As long as we do not check the "apply halftone" box in the Halftone/Underlay dialog, the linked model plots a solid line pattern (which is what we want); however, the lines are too dark. When we check the "apply halftone" box to shade the linked model, the linked model plots as a series of halftone "dots". I have attached a scan of the corner of a plot to illustrate the problem.
The problem seems to be specific to our KIP3100 plotter. If I print to another plotter the lines appear solid and shaded...just like we want them to. Has anybody encountered this issue with KIP plotters? Since the halftone appears like we want it to when we plot elsewhere, I assume that it has something to do with the way we have our KIP set up. Any advice?
Thanks!
