Results 1 to 6 of 6
Thread: AutCAD Classic back to Mechanical
    2006-10
    27
    Default AutCAD Classic back to Mechanical
    My AutoCAD Mechanical has lost its Mechanical component and has become AutoCAD Classic.
    How do I get the AutoCAD Mechanical component back up and running? (2007 version)
    2006-10
    27
    Default Re: AutCAD Classic back to Mechanical
    Under "menuload" is listed ACAD, CUSTOM & VAULT. I think that 'ACAD' should be 'AMACAD'.
    Where should I browse to to find 'AMACAD'?
    150700
    3,439
    Are you just loading the wrong profile?
    you should have two options under your start-->Autodesk (or whatever autoCad shows up under).. AutoCAD and AutoCAD Mechanical
    2006-10
    27
    Using start, Programs & selecting AutoCAD Mechanical 2007, when loaded 'AutoCAD Mechanical' shows in the blue strip at the top of the screen, but in a space below that is "AutoCAD Classic" with the only other toggle option being "3D Modeling".
    When loading, "loading Mechanical modules" flashes on the bottom left hand corner of the screen.
    I can't see how to get Mechanical back.
    150700
    3,439
    Quote Originally Posted by alan.123099 View Post
    Go to your options and see what profile you have loaded.
    2006-10
    27
    I have installed version 2009 in the place of 2007. It has fixed this problem but still have the leader note font problem. Brenda, thank you for your response.
  1. I would like the classic Revit interface back
    Last Post: 2016-10-25, 06:00 PM
  2. Cannot find AutoCAD classic within AutoCAD Mechanical
    By robotgrass in forum AutoCAD Mechanical - General
    Last Post: 2014-08-26, 02:39 AM
  3. How to get back the classic toolbars
    By terence.duggan1910 in forum ACA General
    Last Post: 2010-09-30, 06:36 PM
  4. Cracking The 2010 UI - Go back to classic
    By anthonyf in forum Revit - Platform
    Last Post: 2010-07-29, 09:11 PM
  5. Restore back to AutoCAD Mechanical
    By rhanz in forum Hardware
    Last Post: 2008-06-13, 09:52 PM
