Results 1 to 1 of 1
Thread: Path reinforcement in sloping slab
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default Path reinforcement in sloping slab
    Hi,
    I have a sloping slab (using slope arrow) - I add path reinforcement.
    The path reinf. doesn’t show in sections when it is parallel to the view plane – the pat reinf does however show up when perpendicular to the view plane.
    The area reinf. seem to work OK.
    Anyone ells having the same problem in RST2011?
    J
  1. 2015: Revit Tagging - Slab Reinforcement
    By Lines&Circles; in forum Revit Structure - General
    Last Post: 2015-02-20, 08:06 AM
  2. 2013: Copying path reinforcement
    By ckeelor in forum Revit Structure - General
    Last Post: 2012-08-28, 02:10 AM
  3. Area Reinforcement in slab
    By crickman in forum Revit Structure - General
    Last Post: 2009-07-27, 03:19 PM
  4. The Ability to Create a slab Edge on a Sloping Slab
    By G_J in forum Revit Structure - Wish List
    Last Post: 2009-03-19, 02:28 PM
  5. Modifying Path Reinforcement
    By johk in forum Revit Structure - General
    Last Post: 2008-01-18, 12:10 PM
