Is there a way to split/merge pipe networks in autocad civil 2010?
Sure is. It's not very pretty though but it can be done. First, erase all the pipes and structures from your drawing that you don't want to be in the other pipe network. Export the network out to a LandXML file. Undo the erasing of your pipes (better yet, close and reopen). Erase the pipes that you exported out. Import the LandXLM file.
I haven't tested this so you may run into network name issues so rename your network before you export it.
