Results 1 to 7 of 7
Thread: Undock Ribbon
    2006-12
    Big "D"
    3,711
    Default Undock Ribbon
    Is there any way to undock the ribbon entirely like ACA does?
    I run 3 monitors. I would run ACA stretched across 2 monitors with just the QAT at the top. On my third monitor, I keep the properties palette, tool palette, xref paletts, and project navigator.
    I'd like to do a similar thing in Revit. Is that possible? I've already noticed that, while the palettes stay on the third monitor, Revit will not stay stretched across the othet 2 screens upon launch. I have to redo it every time.
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    Default Re: Undock Ribbon
    The easiest solution IMHO: Port to OSX
    I do not think undocking the Ribbon is possible in Revit.
    2003-04
    Chino, CA
    4,756
    The individual panels can be ripped off of the ribbons and placed on a second (or third!) monitor.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by Scott Davis View Post
    c'mon Scott! ACA can do it. Isn't Revit supposed to be better?
    Yeah, I saw that the individual panels can be ripped off, but I don't want to spend two hours ripping off every panel, then I'd have to do every contextual panel. Then, if I ripped off all the panels, the ribbon would still be there, just blank, right?
    I'll deal with it and hope 2012 can do it.
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    Ripping off Panels is lame. And broken. When you exit sketch mode (like editing the profile of a wall or floor sketch, etc.) the panels re-dock.
    -P
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by Phil Read View Post
    Huh? I just tested in a bunch of different configurations with different panels ripped off and different sketch modes finished, and all panels stayed where I placed them. What are you doing so that I can reproduce it?
    2006-01
    449
    I think it's another one of those YMMV dealios. I just ripped the Build dock off of the home ribbon, clicked back into my main canvas and the build dock disappeared :/
    Hid all opened windows, wasn't there. Clicked a few other ribbons, didn't show back up. Entered the wall command with keyboard, re appeared right where I left it.
  1. Replies: 20
    Last Post: 2015-05-16, 12:14 AM
  2. Replies: 0
    Last Post: 2014-12-01, 03:30 AM
  3. 2012: Undock views or sheets to second monitor
    By turnbullp in forum Revit Architecture - General
    Last Post: 2012-04-25, 04:44 PM
  4. 2011: Error undock md 2
    By rstiles in forum AutoCAD General
    Last Post: 2011-07-18, 05:55 PM
  5. My first Ribbon :-(
    By some-1-2 in forum Revit - API
    Last Post: 2010-09-24, 03:39 PM
