Thread: Transferring to DWG from revit 2011
    2008-10
    10
    Default Transferring to DWG from revit 2011
    Hello to everyone
    I triying to link a model from revit 2011 to max 2011, using the file link manager, but i had a problem, when i open the model in max, the revit families, the create in place ones, and the create outside, almost all come without textures, and i didnt know why, i doesnt had this problem with previous releases os revit.
    someone can help me with this problem?
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Wink Re: Transferring to DWG from revit 2011
    Try using FBX export from Revit instead of DWG.
    cheers
    PS--the title of your post is a bit misleading.......
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2008-10
    10
    Default Re: Transferring to DWG from revit 2011
    I don´t like the FBX format, because the materials transfer with generic names, and not with the names that i put in the revit model, and this, is really annoying.
  1. New Robot models inheriting old data when transferring from Revit
    By leon.sullivan181291 in forum Robot Structural Analysis
    Last Post: 2011-09-08, 01:25 PM
  2. FBX Woes from Revit Arch 2011 to MaxDesgin 2011
    By r.grandmaison in forum 3ds Max - General
    Last Post: 2010-06-29, 02:54 AM
  3. Is AutoCAD 2011 included with Revit Structure Suite 2011
    By durentech in forum Revit Structure - General
    Last Post: 2010-06-24, 01:27 AM
  4. transferring from REVIT to CAD - layers/colours/lineweights
    By pshupe.159931 in forum Revit Architecture - General
    Last Post: 2010-03-17, 06:03 PM
  5. Replies: 2
    Last Post: 2009-09-11, 07:03 PM
