Thread: Failed to open document
    2006-04
    30
    Default Failed to open document
    Sending a Revit 2011 file (13MB) and it is received by another Revit 2011 user, but this error message comes up. What does it mean?
    Certifiable AUGI Addict twiceroadsfool's Avatar
    2006-01
    4,516
    Default Re: Failed to open document
    If its not workshared, did you send it while you were still in it? ive seen that a lot when i did that. Get out of it and try sending it again.
    2006-04
    30
    File isn't workshared, and it was zIpped.
    2006-01
    4,516
    Quote Originally Posted by welcomehomestudio View Post
    I understand. When you made the zip, was someone still IN the file IN revit? Ive had trouble sending NONworkshared files when someone was still in them.
    2004-01
    Columbus OH
    465
    Also this might seem basic but I've seen it happen. Make sure that the .rvt file has been extracted from the .zip folder. If its still packed in the .zip file you won't be able to open it.
    2006-04
    30
    The problem is the email server. Limit to file attachment: 8MB with Verizon, eventhough Microsoft Outlook accepts 20MB. I switched to a secure FTP site.
  1. 2012: Failed to Open Document
    By Baldwin_4-6-0 in forum Revit Architecture - General
    Last Post: 2013-03-04, 05:34 PM
  2. Issue: Failed to Open Document
    By j.pilot in forum Revit Structure - General
    Last Post: 2012-01-31, 04:01 PM
  3. Failed to Open Document
    Last Post: 2008-01-19, 03:22 PM
  4. Failed to open document
    By lhanyok in forum Revit Architecture - General
    Last Post: 2007-02-09, 09:55 PM
  5. Error Message: Failed to Open Document
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2006-10-06, 12:24 PM
