Thread: Install Revit Error "/SecondRun /Language en-us"
    2007-10
    46
    Default Install Revit Error "/SecondRun /Language en-us"
    See attached image. Revit 2011 will not install - Why?
    2007-10
    46
    Default Re: Install Revit Error "/SecondRun /Language en-us"
    Also has the same error when trying to install ASD 2011..
    I already have Civil 3d 2010 on the computer.
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Try cleaning out your temp folders and then try and load the disc again. If it still gives you the same error go and have a look at your event viewer and see what error it gives you.
    2007-10
    46
    Cleaning out the Temp folder still gives the same problem. what is the event viewer?
  1. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  2. Replies: 4
    Last Post: 2006-11-10, 02:50 PM
  3. Replies: 1
    Last Post: 2005-11-15, 06:35 AM
  4. v8 install probs, "Error code 0"
    By Kroke in forum Revit Architecture - General
    Last Post: 2005-04-27, 05:40 AM
