Thread: Cannot find the specified drawing file
    2004-06
    335
    Default Cannot find the specified drawing file
    Another architect sent me a zip file with dwg, TXT, FMP, TPF, SHX, and CTB files in it. I opened up the zip file and double clicked on one of the dwg files to view it in DWG TrueView 2010. An external references dialog box opened listing three files: the DWG that I opened, and two other dwg files that are in the zip file listing both of their status's as not found. I double clicked on one of them and a select file window opened, however after navigating to the location of that file and selecting it I received the DWG TrueView message "cannot find the specified drawing file." My only option is to select okay, which then repeats the process. I have tried selecting all three of the DWG files therein with the same results. And I can't cancel this action. What am I doing wrong?
    I no longer own, and have not used, autocad for many years. Please advise.
    2000-01
    Seattle WA USA
    5,859
    Default Re: Cannot find the specified drawing file
    Don't try to open the DWG files directly within the ZIP file. Extract all the files first.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Find existing drawing file scale in Modelspace
    By Binu Mathew in forum AutoCAD General
    Last Post: 2007-04-12, 02:45 PM
  2. Find what drawing files a Xref file belongs to
    By basport in forum AutoCAD General
    Last Post: 2007-03-22, 05:13 PM
  3. How to convert a pcx file (scanned drawing file) to AutoCAD drawing file
    By avinash00002002 in forum Raster Design - General
    Last Post: 2007-01-24, 03:12 PM
  4. Replies: 12
    Last Post: 2006-06-27, 07:45 AM
  5. Find which DWT file was used when creating a drawing
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2006-06-08, 05:14 AM
