Thread: cut host using face based GM
    2006-08
    636
    Default cut host using face based GM
    anyone tried using face based GM to cut through loaded user family? seems it only works for system family like wall, etc.
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    Default Re: cut host using face based GM
    Why not load the face based GM into the family that you want to cut?
    2006-01
    4,516
    Thats the only way itll work. if you want to cut a countertop, LOAD it in the countertop. sad face.
    2006-01
    449
    I'm not 100% positive, but I think an in-place family of the same category can cut user loaded families. I'll check and report back.
    2006-08
    636
    thanks Carl and Aaron.
    well, it has to cut through loaded user family as no certain location/angle patterns for that face based GM within that user family, see attached jpg, i have to take out siding from gable family and model it as separate wall, seems that's the only choice before i resort to API.
  1. Void in family cuts face based host?
    By ron.sanpedro in forum Revit Architecture - Families
    Last Post: 2018-02-23, 04:25 PM
  2. Replies: 2
    Last Post: 2014-10-16, 10:57 AM
  3. 2014: Face Based Host vs. No Host
    By slovenc0417 in forum Revit MEP - Families
    Last Post: 2014-04-17, 02:23 PM
  4. Use Face Based Void Family to Cut Host Beam Family?
    By matt.fleming in forum Revit Structure - General
    Last Post: 2011-05-28, 01:53 AM
  5. Allow face based families to have either a vertical or horizontal host element.
    Last Post: 2008-10-22, 10:02 PM
