Results 1 to 7 of 7
Thread: Concrete Beams with Toe
    2007-01
    10
    Default Concrete Beams with Toe
    Hi Guys,
    Forgive me as I know this is probably a simple problem to some of you but I'm new to Revit and am having to learn it as I go along.
    I need to model a concrete ground beam with a toe on one side to support some brickwork so in effect an L shaped beam.
    Ideally I'd like the toe projection and depth to be adjustable but the bottom of the toe will always line through with the bottom of the main part of the beam.
    I tried modifying the existing concrete rectangular beam family but got frustrated and thought it might be quicker to seek some advice!
    Anyone have a family they've made up like this or can point me in the direction of a tutorial?
    I'm in the UK so metric would be preferred.
    Thanks guys!
    Adam.
    2007-01
    10
    Default Re: Concrete Beams with Toe
    No worries, I think I've cracked it
    2009-06
    Cape Town, South Africa
    109
    Will you be willing to share the family?
    2006-05
    836
    The content generator can produce these without having to build them.
    2003-11
    Sutton Surrey United Kingdom
    238
    "content generator", please do tell more?
    Active Member Mike hacker's Avatar
    London
    64
    It's part of the Revit Extensions.
    2008-04
    270
    Hopefully the attached family will do the trick.....?
    Regards
    Glenn
  1. Curved Concrete Beams
    By wesleybarnes237 in forum Revit Structure - General
    Last Post: 2008-04-01, 05:15 AM
  2. Joining of Concrete Beams
    By djn in forum Revit Structure - General
    Last Post: 2007-12-18, 11:04 PM
  3. Better control of concrete beams
    Last Post: 2007-12-15, 04:31 PM
  4. Tagging Concrete Beams
    By paullee in forum Revit Structure - General
    Last Post: 2007-02-09, 04:53 PM
  5. Concrete Beams (i wish)
    By jakob_k in forum ACA Wish List
    Last Post: 2007-02-05, 08:32 PM
