I'm currently using Revit MEP 2010 and will be installing 2011, in the next few days.
I'm currently trying to do a schedule to calculate watts per square metre (lighting load) for lighting to get the actual and the specified for an area (space).
Also to get the schedule to highlight spaces that are over the specified watts/m².
I'm using a 'space schedule' with an embedded 'lighting fixture' schedule, as the 'lighting schedule' does not have a parameter for area for a space only volume.
I can get everything to work except the actual load for the space, which is giving me about 5% less then what the total should be. The load parameter that is in the lights is right and when I turn on the 'calculate' for the load parameter column, it is giving the right amount. I can't find any setting in the light/space families that might be causing this error, or in the electrical settings.
Has anyone had excess with doing this, or know what could be causing this error.
