Thread: Revit 2011 and Cut Profile
    2007-11
    Buffalo, NY
    100
    Default Revit 2011 and Cut Profile
    Has anyone else seen this, when you have a floor coming into a wall and want to cut it back for an expansion joint. In Revit Arch 2011 if you have a structural deck in your floor and try to use a cut profile it will leave the structural deck the full length and only cut backthe 2 portions of the floor. Any one else wanna give this a shot and see if it does the same thing?
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    999
    Default Re: Revit 2011 and Cut Profile
    I looked into this issue, and yes, the same happens here. I guess the original design of that deck contains a solid object (the concrete portion) and a couple of symbolic lines representing the steel deck. Therefore the Cut profile tool only cares about the solid part, leaving the rest of the symbolic lines there. Since we can't use Edit family on this, the only solution I found was to hide that left over portion of the symbolic lines with masking regions made with invisible lines.
  1. Revit FBX 2011 Material Editing in 3ds Max 2011
    By pras3rt in forum Revit - Rendering
    Last Post: 2011-10-15, 10:20 AM
  2. Revit 2011 to Max Design 2011 to Backburner
    By mbeham in forum 3ds Max - General
    Last Post: 2011-01-14, 10:47 PM
  3. 2011: ACA 2011 freezes when a profile is changed
    By RayRuiz in forum ACA General
    Last Post: 2010-07-29, 10:38 PM
  4. FBX Woes from Revit Arch 2011 to MaxDesgin 2011
    By r.grandmaison in forum 3ds Max - General
    Last Post: 2010-06-29, 02:54 AM
  5. Is AutoCAD 2011 included with Revit Structure Suite 2011
    By durentech in forum Revit Structure - General
    Last Post: 2010-06-24, 01:27 AM
