Hello
using 2008
when I paste anything using Ctrl V or from the pull down it takes a long time for it to actually do anything. is there that can be done other than going back to 2007
Hello
using 2008
Start two new empty (use no template) drawings.
Draw a line in one, copyclip the line from here and then pasteclip into the other drawing.
Is this just as slow?
Copyclip writes a DWG file to your %temp% directory and Pasteclip inserts it.
Maybe the drawings you are working with have tons of scale list entries, or regapps, etc. making them really large? Take a look in your %temp% directory after running CopyClip.
R.K. McSwain | CAD Panacea |
My guess is you have a huge number of scales in your scales list.
Reset the list by running -SCALELISTEDIT (notice the minus sign for command line options), Reset option, then Exit option.
