Thread: Arc Lengths
    2004-05
    7
    Default Arc Lengths
    I am sure I am missing something easy, but I am all of sudden unable to get the arc length dimensions to work. I am trying to dimension vertical mullions on a curved curtain wall. Revit prompts me to pick the arc to dim, but will not pick any intersecting references to dim. Any help would be greatly appreciated.
    Justin Hosler
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Arc Lengths
    Try this:
    When it prompts you to pick the arc to dimension, first pick the endpoint of the curtain wall arc, & then you'll be able to pick & dimension the grid line points.
    2004-05
    7
    I knew something simple would do the trick, thanks for the reply.
  1. Add up line lengths
    By bmckenzie in forum AutoLISP
    Last Post: 2014-01-03, 06:32 PM
  2. how to dimension arc lengths?
    By Mike Y in forum Inventor - General
    Last Post: 2009-04-13, 01:07 PM
  3. Profile Pipe Lengths
    By walford in forum Land Desktop - General
    Last Post: 2008-06-11, 07:16 PM
  4. polyline lengths
    By eebryant in forum AutoCAD Map 3D - General
    Last Post: 2006-11-04, 01:18 PM
  5. tangents and lengths
    By Statler in forum AutoCAD General
    Last Post: 2006-10-30, 11:03 AM
