Thread: Alignment Station label that is perpendicular to alignment
    2007-08
    Little Rock, Arkansas
    3
    Default Alignment Station label that is perpendicular to alignment
    Is it possible to make an alignment label style that shows the alignment station perpendicular to the alignment? This would be an almost exact copy of the OTB Horizontal Geometry Labels except I want it to be at a station that I specify.
    I can get the label to look the same as the PI labels but it will only orient itself to a definite angle. There is no option (that I know of) that will allow my label to be perpendicular to the alignment.
    Any ideas? Thanks.
    Corbitt
    2001-05
    Austin, TX USA
    2,201
    Default Re: Alignment Station label that is perpendicular to alignment
    Under the "General tab" set "Orientation Reference" to Object. Under the Layout tab, change the "Rotation Angle" to 90°.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2007-08
    3
    I appreciate the quick response. My orientation reference is locked to "view" and it is also locked in the label style defaults. I can't find any way to unlock this, but I'm sure I'm overlooking something simple.
    2001-05
    Austin, TX USA
    2,201
    Go to the settings tab in the Toolspace palette. Right click on the active drawing name and select "Edit Label Style Defaults". Expand "Behavior" and make sure Orientation Reference is unlocked.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    2007-08
    3
    That's where it was. Thanks a bunch.
  1. Adding Station Equation to Alignment
    By nigel.rollo354991 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-01-07, 03:26 PM
  2. Alignment Station Direction
    By Ryan-13 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2011-10-04, 09:03 AM
  3. A though question on alignment - station labeling
    By ebarlevi in forum AutoCAD Civil 3D - General
    Last Post: 2007-10-16, 12:04 PM
  4. alignment drawing in inches, can't station
    By Maverick91 in forum Land Desktop - General
    Last Post: 2007-03-14, 04:44 PM
  5. Alignment with station and offset?
    By todd.80290 in forum Land Desktop - General
    Last Post: 2006-03-27, 10:58 PM
