Results 1 to 7 of 7
Thread: parametric asignment of materials to imported object in revt ?
    2009-12
    4
    Default parametric asignment of materials to imported object in revt ?
    I have worked on assigning materials to imoprted CAD-objects in REVIT-families.
    So far i succeeded by using the assignement within the "object styles" -> "imported objects" dialog seeing to have the imported CAD in sorted layers.
    Is there though any way to have this assignement by a type-parameter, so that i don´t have to make a single familyobject for each appearance ?
    2006-01
    4,516
    Default Re: parametric asignment of materials to imported object in revt ?
    Not if its imported CAD geometry.
    2015-12
    Orlando, FL
    1,049
    Yes, not if it is just an imported CAD geometry.
    As an alternative, you may try this: In a generic model family, bring your imported CAD object, and using that geometry as a reference, you need to rebuild it as a native 3d object in Revit. It would be more work, yes, but this is the only way to can control its material with a parameter, as you wish.
    After you have created your 3D model, you can erase the imported object. Go to Manage > Materials, and create "Material 1", Material 2", "Material 3", etc. Go to the the Family Types icon, and create a new type parameter, such as "Object material", which will be of "Material" type. Then, create new types, such as "Type 1" using "Material 1", "Type 2", using "Material 2", etc. Load into your project. Now, you should be able to have different versions of your object, with different materials.
    2009-10
    154
    I had a some weird behavior in this department yesterday. Had a furniture family with imported cad geometry. Opened it, changed the material, saved out as a different family, and re-inserted. In the family editor, the material is different. In the project, it doesn't change! My guess is that even if the cad blocks are in separate families, they are in the same line in the object styles list, so have the same material. I guess the next thing to check is renaming the cad block, importing into a second family, changing the material and reimporting...
    ...or just building the stupid thing in revit
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: parametric asignment of materials to imported object in revt ?
    bregnier,
    Yes to all........
    cheers
    2009-12
    4
    Hi all !
    Thank´s for your replies and sharing of experience.
    Pittsburgh, PA USA
    1,906
    Here is a timely glog post on this issue, from the Factory.
    http://revitclinic.typepad.com/
  1. 2013: Multiple Materials in a Parametric MvPart
    By drewj in forum AMEP General
    Last Post: 2013-03-21, 09:10 PM
  2. Assigning materials on an imported family object
    By nso in forum Revit Architecture - General
    Last Post: 2011-02-15, 06:47 PM
  3. parametric materials not working
    By dzatto in forum Revit Architecture - Families
    Last Post: 2010-07-06, 01:20 PM
  4. Can't change materials on some imported models
    By DoTheBIM in forum Revit - Rendering
    Last Post: 2010-01-13, 01:10 AM
  5. Materials in imported files available for parameters
    By janunson in forum Revit Architecture - Wish List
    Last Post: 2005-11-30, 10:19 PM
