Thread: google earth terrain cut + fill
    2009-01
    San Francisco, CA
    289
    Default google earth terrain cut + fill
    I imported a sketchup file that has the google earth terrain in it.
    I want to know what's the best way to do the 'cut + fill" of the terrain?
    Like trying to figure out how much terrain (volume) needs to be excavated for the building?
    How do I do the "cutout" of the footprint of the building into the terrain?
    Thanks in advance,
    David
    I could stop if I wanted to mthurnauer's Avatar
    2001-11
    Cincinnati, formerly Chicago
    388
    Default Re: google earth terrain cut + fill
    I don't know how precise a google earth terrain will be, but that aside... Bring the terrain in and phase it as existing. Then do a graded region and pick to copy internal points. Next, create a building pad at the desired elevation and the pad should subtract out of the new site you should be able to do a cut/fill schedule.
    100 Club r.grandmaison's Avatar
    2003-11
    location location
    192
    Easiest way to do it is to first finish the existing topography making any adjustments as necessary to make sure it's correct. Then once done, edit he properties on it to indicate that it's existing. Then copyclip the terrain into the clipboard and paste it back in to the exact same place. Select one of the terrains and then change its status to New Construction. Turn off the display of existing phases and then use the topography tools to change the spot elevations to reflect cuts/fills in your "new" terrain, create subregions, bulding pads, etc...
    Now create a schedule for the category of Topography, and include whatever fields you like (usually cut and fill).
  1. google earth connection - globe link vs google earth extension
    By rpict in forum Revit Architecture - General
    Last Post: 2010-06-21, 03:27 PM
  2. Replies: 5
    Last Post: 2008-09-30, 12:48 PM
  3. Avatech Earth Connector for Google Earth
    By Tobie in forum Revit Architecture - General
    Last Post: 2006-07-11, 12:47 PM
  4. Earth Connector for Google Earth ( freeware )
    By Mike.Perry in forum AutoCAD General
    Last Post: 2006-01-06, 11:22 AM
