Thread: double-click for text edit
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default double-click for text edit
    I just installed ACAD '11. When I double-click on text or dimensions, I get the properties box. I want the text editor. How do I make this change? TIA
    2001-05
    Austin, TX USA
    2,201
    Default Re: double-click for text edit
    Go into your CUI and look under "Double Click Actions". Create a new action and give it a name and add the Object name you want to edit.
    Example: for dimensions you'll put DIMENSION.
    Then drag the DDEDIT command from the command list pane to your newly created action.
    1,324
    Quote Originally Posted by Glenndp View Post
    Thanks, Glenn. I've got that partially working. It works on text and mtext, but double-clicking still doesn't work on dimensions.
    2001-05
    Austin, TX USA
    2,201
    Do you have the action placed in the main CUI? Mine is placed in the c3d.cuix.
    2015-02
    In my case when I double click it change FONT to default and somehow I didn't have that font loaded, you can check this if you change text to mtext (TXT2MTXT), there's a "preview", on the ribbon, that it won't show, because you are missing that font, the way you can fix it is going to options (OP), add the path where your fonts are store, this is on the tab "files", and "Support File Search Path", press "Add" button, and press button "Browse" to add that path, or simply change the font on that specific "Font style" type the command "Style" and change it, hope it helps....
  1. Can't double click to edit text.
    By Darren Allen in forum AutoCAD General
    Last Post: 2013-11-23, 06:09 AM
  2. double click to edit text is broken.
    By slapthefunkyfour in forum Software
    Last Post: 2008-08-07, 09:07 PM
  3. double click edit is gone
    By clovis in forum AutoCAD Mechanical - General
    Last Post: 2007-10-10, 02:33 PM
  4. AutoCAD 2007 - Double click Text, Attributes to edit them
    By rflores.74287 in forum AutoCAD General
    Last Post: 2006-07-18, 06:14 PM
  5. Double Click to 'Edit'
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-10-27, 12:43 AM
