Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Revit 2010 - Plot PDF to Combine into One Document Gets Stuck
  1. #11
    2006-04
    12
    Default Re: Revit 2010 - Plot PDF to Combine into One Document Gets Stuck
    Quote Originally Posted by nweeks View Post
    This may have been fixed by now (Revit 2012), I haven't checked. But the multiple printing was happening because in the selected views/sheets dialog, multiple views/sheets were selected. That is, in addition to multiple views/sheets being "checked" they were also "selected" (multiple sheets/view names were highlighted in dark blue). If you deselect ( but leaving multiples checked) the printing would run as expected.
    Not in my case.. I can start with a clean boot, load the file, print from a saved list and it still happens 99% of the time.
    I have had this issue on 5 different computers with 3 different versions of REVIT Arch using both CutePDF & a few different versions of Adobe.
  2. #12
    2007-10
    9
    Just an update: I am using Revit 2012 MEP and Adobe PDF. I get caught in the print loop every time when printing multiple sheets to a combined pdf.
  1. Revit 2010 > Design Review > PDF/Plot
    By Munkholm in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-10-24, 09:03 PM
  2. Plot Document Name
    By darin.marsden in forum AutoCAD Plotting
    Last Post: 2007-12-04, 11:06 AM
  3. Drawings Stuck in STB plot styles
    By m.cullen in forum AutoCAD General
    Last Post: 2005-04-07, 01:05 AM
