Thread: Foundations Shown Dashed in Elevation
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default RE: Trasnparent Topography in Section/Elevations
    My method in sections and elevations is to...
    1. Turn off the visibility of the topo in the view.
    2. Use linework to select all the foundation lines and set them to hidden -or- use detail lines (with pick and lock) and select the foundation lines.
    3. Turn topo on again and your lines will display.
    Christopher Herr
    Studio H:T
    Republic of Boulder
    All AUGI, all the time Allen Lacy's Avatar
    2003-04
    Richmond, VA
    545
    Default Re: Foundations Shown Dashed in Elevation
    I think the consensus is (if you're using topo) to turn off topo, use the linework tool to change foundaton lines to hidden, turn topo back on. This way, if you move or change the location of foundation, the linework goes with it.
  1. Owner Provided Items Shown Dashed
    By TerribleTim in forum Revit Architecture - General
    Last Post: 2012-03-10, 10:56 PM
  2. Door Swing Elevation Lines - Not Dashed...
    By eroq in forum Revit Architecture - General
    Last Post: 2011-03-18, 07:33 PM
  3. Foundations as Hidden Lines in Elevation Views
    By bclarch in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-06-30, 03:23 AM
  4. Foundations in Elevation
    By jcoe in forum Revit Architecture - General
    Last Post: 2004-10-21, 03:17 PM
  5. Dashed lines not dashed in Layout view
    By pford in forum AutoCAD General
    Last Post: 2004-06-15, 07:54 AM
