Results 1 to 1 of 1
Thread: NFC on Titleblock
    2003-11
    New Zealand
    1,116
    Default NFC on Titleblock
    You can't do it with visibility. In V7 when you haven't set a project information parameter it won't show anything. So we use this technique to achieve what you want.
    I don't know how to make the images inline, hopefully this will make sense:
    Open your Titleblock and add a label. Create a new text shared parameter (here called NFC).See attached image. Format the text label as required.
    Now open your project(template) and add the new Titleblock.
    Go to settings->project parameters and add the shared parameter to project information categories. See attached image.
    Now when you go to project Information you will see the label and you can edit the text. Or leaving the label empty will not show any text across all sheets that use this titleblock.
    HTH,
    Guy
  1. drawings on 30x42" titleblock: client now wants 11x17" titleblock
    By graphite in forum Revit Architecture - General
    Last Post: 2011-11-08, 06:05 PM
  2. Titleblock help
    By stevenw00 in forum AutoLISP
    Last Post: 2009-06-12, 12:52 PM
  3. Titleblock Changes
    By rjcrowther in forum Revit - In Practice
    Last Post: 2007-05-03, 06:13 PM
  4. titleblock
    By bennetttwin in forum Revit Architecture - General
    Last Post: 2004-12-20, 05:46 PM
  5. Convert 2436 titleblock to 3042 titleblock?
    By m_cahoon14336 in forum Revit Architecture - General
    Last Post: 2004-08-23, 04:45 PM
