Thread: Metal stud DB rotate issue
    Active Member beardking's Avatar
    2009-07
    82
    Default Metal stud DB rotate issue
    I have the attached DB that I originally got from somewhere online (possibly right here even). I've made 1 change to it and that is to add a rotate action to it. I can't seem to get the rotate to work correctly. If I insert the block and adjust the size of the stud via the lookup and THEN rotate, all is well. But if I try to adjust the size after I've done the rotate, all kinds of things go wonky. Anyone of you gurus out there wanna help a man out?
    Thanks in advance.
    Beardking
    Using AutoCAD 2009 to about 60% of it's potential daily.
    2004-07
    Baton Rouge, Louisiana
    173
    Default Re: Metal stud DB rotate issue
    here i fixed the block by redoing the rotation, when it ask to select objects, i selected every thing for the rotation
    2009-07
    82
    Aha. I see what I did wrong. I had all of the actions selected and you didn't. Cool. Now I can use this thing more efficiently, as planned.
    Thank you very much.
    2004-07
    173
    no problem, gald to help
  1. Light Gage Metal Stud
    By Thomas Maleski in forum Revit Structure - Families
    Last Post: 2010-11-29, 11:28 PM
  2. How do I represent a Metal Panel Wall or Metal Roofing?
    By rgecy in forum Revit Architecture - General
    Last Post: 2009-05-09, 05:35 PM
  3. Metal stud at the end of the wall as well as repeat every 16"
    By spddesigns in forum Dynamic Blocks - Technical
    Last Post: 2007-05-24, 02:59 PM
  4. 6" Metal Stud Wall @ 16" o.c.
    By aokane in forum Revit Structure - General
    Last Post: 2006-03-08, 03:21 PM
