Thread: Walkthrough Path
    2007-01
    Default Walkthrough Path
    I currently have several Walkthrough Paths in Revit Architecture 2011 that I would like to export to AutoCAD and eventually bring that into Max. The scene is getting more complex and I need to finish the renderings in Max. Is there a way that I can export the walkthrough path to a 3d line so I can bring it into Max and then attach a camera to it?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Walkthrough Path
    I believe that when you export via FBX from RAC 2011 to 3dsMax Design 2011,
    you can specify cameras and walkthru paths.........
    We have not actually tried this, but as I recall it may be possible.
    If that does not work, as a workaround,
    you could try saving an image from Revit with the walkthru
    path shown in a plan view. Then take the image into Acad and trace it quickly with
    a polyline, then import that into Max.
    I don't think it's possible to export the walkthru path from Revit as an object?
    cheers
  1. Exporting Walkthrough Path to 3DMAX
    By liorman in forum Revit Architecture - General
    Last Post: 2011-10-01, 01:07 AM
  2. Walkthrough path
    By charliep in forum Revit Architecture - General
    Last Post: 2010-05-29, 10:34 AM
  3. Controlled walkthrough path
    By Grumple in forum Revit Architecture - General
    Last Post: 2009-09-10, 10:48 AM
  4. Edit Walkthrough Path
    By matt__w in forum Revit - Rendering
    Last Post: 2009-06-24, 11:42 PM
  5. Walkthrough Path Distance
    By Steve_Stafford in forum Revit Architecture - Wish List
    Last Post: 2005-01-07, 05:38 PM
