Results 1 to 10 of 15
Thread: Leaders with No Text
    100 Club r.grandmaison's Avatar
    2003-11
    location location
    192
    Default Leaders with No Text
    If you'd like a leader without any text you can use the Text tool to create one, but there's a bit of a workaround- until I find out if Revit can support Unicode Format codes within standard text via keyboard entry...
    1. Create an aligned dimension and edit the text within the dimension.
    2. Choose the "Replace Text" option.
    3. Right mouse click inside the text field and choose "Show Unicode Control Characters..."
    3. Right mouse click again and choose "Insert Unicode control characters..." and the select the "LRM/Left-to-Right" control code.
    4. Right mouse click inside the text field and select "Select All".
    5. CTRLl+C to copyclip the Unicode Format Control LRM into your windows clipboard.
    6. Start a text with leader and when the text field opens, CTRL+V to paste the LRM into your text.
    7. Click Modify to finish the command.
    You should now have a leader without any visible or printing characters or text associated with it!
    You can add additional leaders to the "text object" or remove them but, you cannot edit the text in the note once youv'e done this as it's not selectable. The same is true of a dimension that you may have replaced text with only the Unicode character.
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    599
    Default Re: Leaders with No Text
    another workaround to choose from:
    1) create new annotation family w/o anything added except naming that family properly
    2) load into project
    3) select that family
    4) add as much leaders as needed
    Active Member todd.69291's Avatar
    2004-06
    Aurora, Colorado
    56
    Try this one
    Todd Behning
    CAD/BIM Manager
    Merrick and Company
    Aurora, CO
    www.merrick.com
    todd.behning@merrick.com
    2003-11
    location location
    192
    Quote Originally Posted by todd.69291 View Post
    Try this one
    Gee, when you said "blank leader" you weren't kidding were you??? Maybe you should have called it "blank.rfa" instead?!?!?
    2004-06
    Aurora, Colorado
    56
    When you placed the leader in the view it will default to 0 leaders. Increase the number of leader to one or more before placing.
    Todd Behning
    CAD/BIM Manager
    Merrick and Company
    Aurora, CO
    www.merrick.com
    2005-12
    Greeley, CO
    115
    Another workaround.
    1. Create a text style with a text height as small as Revit will allow.
    2. Start the text tool select the super tiny text style.
    3. Place your leader and type "."
    There is text next to the leader, but once it's plotted no one will ever know.
    2004-05
    Auckland, New Zealand
    340
    This "text" option is the one that i use - Easy for other users to figure out!
    AUGI Addict cdatechguy's Avatar
    2004-02
    CdA, ID
    1,371
    Quote Originally Posted by bearden383 View Post
    Another workaround.
    Add enough of these and your prints would look AutoCAD like...
    "Why are there these small dots? I thought we were using Revit not AutoCAD?!"
    LOL
    Michael "MP" Patrick
    "I never make stupid mistakes. Only very, very clever ones."
    2005-12
    Greeley, CO
    115
    Quote Originally Posted by cdatechguy View Post
    LOL
    That's the great part, unless you have dozens aligned right next each other you will never actually see the period.
    AUGI Addict DaveP's Avatar
    2003-11
    St Paul, MN
    1,364
    Unless you have on Oce plotter.
    Some of the Oce drivers (especially the older ones) crash if you have Text smaller than 1/128"
    And THAT wasn't easy to track down!
    Go back to AutoCAD? I'd rather lose my right arm!
  1. Leaders with no text
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2011-12-24, 06:20 PM
  2. Leaders with not text
    By ncassidy in forum Revit MEP - General
    Last Post: 2011-02-07, 01:48 PM
  3. Text Leaders
    By STHRevit in forum Revit Architecture - General
    Last Post: 2009-05-14, 05:09 PM
  4. Text w/ Leaders
    By Wesley1969 in forum Revit Architecture - General
    Last Post: 2007-10-05, 05:22 PM
  5. Text Leaders detaching from text/arrows
    By cphubb in forum Revit Architecture - General
    Last Post: 2003-11-26, 06:14 PM
