Thread: wall patterns w/ studs & insulation
    2004-07
    Dallas
    46
    Default wall patterns w/ studs & insulation
    has anyone developed a wall cut pattern showing studs and insulation for a plan view? if so, has it been able to adjust with the size of the wall, or should a pattern be made for each wall thickness? thanks! ~sarah
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    Default Re: wall patterns w/ studs & insulation
    I think that is the wrong way to it it, you need to use detail components and link them to your wall so any section will show the detail component...you can also make it parametric (ie: number of noggings etc changes per height of wall)...check out this tread
    http://forums.augi.com/showthread.php?t=272
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
    2004-07
    Dallas
    46
    but that would require tons of linework for each wall, correct? and i'm looking for something more automatic. if there were a fill pattern showing studs and insulation to be used as the cut pattern of the structure layer of a wall, that would display correctly everywhere. that's more what i'm looking for. if no one has done this yet, i will likely do it and post the .pat on this thread later.
    2003-04
    Chino, CA
    4,754
    What I would like, is the ability to define in the Wall Properties, repeating detail components. I would like to be able to 'preview' the wall plan view in the Wall Props, and 'sketch' the correct repeating detail component into the wall type. Then we should have the ability to set whether that detail component shows at coarse, medium, or fine Visibility settings.
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
  1. Wall Studs
    By terence.duggan1910 in forum Dynamic Blocks - Sharing
    Last Post: 2011-09-16, 01:23 PM
  2. Viewing Wall Studs- Coarse vs Medium
    By ededios in forum Revit Architecture - General
    Last Post: 2009-03-03, 04:37 AM
  3. Replies: 8
    Last Post: 2007-08-06, 04:31 PM
  4. Wall Studs and Wall Footing
    By keyvan in forum Revit Structure - General
    Last Post: 2006-08-25, 08:33 PM
  5. Variable height/variable count family (studs in a sloped wall)
    By DoTheBIM in forum Revit Architecture - Families
    Last Post: 2006-06-15, 02:48 PM
