Thread: distance routine
    2010-06
    2
    Default distance routine
    I have a little problem.
    My boss asked me to develop a routine that can measure a distance between several points.
    So far i've able to use the distance command but this distance need at least three points.
    Anyone can help me?
    Thanks so much in advance.
    AUGI Addict alanjt's Avatar
    2008-02
    1,073
    Default Re: distance routine
    Quickie...
    • File Type: zip cd.zip (804 Bytes, 30 views)
    Civil 3D 2011|2012 ~ Windohz 7
    Dropbox | finding the light…
    2010-06
    2
    Red face Re: distance routine
    Im sorry for the delay (too much work here) but thanks i will check it out...
    best regards.
  1. Surveying Bearing/Distance LISP Routine
    By BoarsNest01 in forum AutoLISP
    Last Post: 2012-09-27, 04:29 PM
  2. Array distance linked to scale distance
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2011-10-13, 06:42 PM
  3. L'art et la manière de travailler a distance : VPN ? Bureau à distance ?
    By drophouse in forum Revit Architecture - L'art et la manière
    Last Post: 2008-08-23, 12:58 PM
  4. Distance command in Paperspace, returns Modelspace distance.
    By chuck_cantieny in forum AutoCAD General
    Last Post: 2006-09-21, 04:00 PM
  5. Distance Lisp Routine Help
    By BCrouse in forum AutoLISP
    Last Post: 2006-02-11, 11:41 PM
