Thread: Imperial Dynamic Bolt
    2010-03
    5
    Default Imperial Dynamic Bolt
    I have altered this drawing so that I caould use it at Imperial scale (1/4", 3/8", ect) insted of Metric. I got it to work fine for 1/4" - but when I move up the scale of sizes, the washers / nut are spaced off the bolt shaft. any way that I can keep the washer / nut attached to the bolt shaft? (I copied the drawing of a Structural bolt from Mr Cory.)
    2010-03
    5
    Default Re: Imperial Dynamic Bolt
    Here is a drawing of all of the possible variations. You can see where my problem ocurs...
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    what version of ACAD are you using?
    Sometimes, i get lost in my own thoughts and need to ask directions to find my way back.
    S&D DB Sharing Forum
    2010-03
    5
    Using AutoCAD 2009 (I do have 2010 - but have had some problems with it so am using 2009 for most).
  1. Dynamic Bolt Help
    By jjanis in forum Dynamic Blocks - Technical
    Last Post: 2010-07-29, 01:55 PM
  2. Imperial Bolt
    By gessex in forum Dynamic Blocks - Technical
    Last Post: 2010-03-16, 05:37 PM
  3. Structural - Dynamic Expansion Bolt
    By jeffc.engineer in forum Dynamic Blocks - Sharing
    Last Post: 2010-03-11, 05:25 PM
  4. Making a U-bolt block dynamic
    By rolibolibo in forum Dynamic Blocks - Technical
    Last Post: 2007-03-07, 08:28 PM
  5. Structural - Dynamic Anchor Bolt
    Last Post: 2007-02-16, 09:33 PM
