Thread: How to check a RC column with specific reinforcement?
    2010-01
    144
    Default How to check a RC column with specific reinforcement?
    Hi, I need to to design a column with 25 bars around it (6 bars on each edge) but I did not find any option for selecting longitudinal reinforcement pattern in reinforcement pattern dialog box.
    I could draw them manually but this takes so much time(I have to insert coordinates of each bar). Is there any quick way for defining such column reinforcement? It is so easy to create such section in Etabs ..
    2010-01
    144
    Default Re: How to check a RC column with specific reinforcement?
    Is this the only shape Robot can design?
    2007-05
    Krakow, Poland
    34
    Hi,
    RSA 2011 brings a parametric definition of a column's reinforcement cage and run verification (insted of AutomaticDdesign),
    You can also import a reinforced columns defined from Revit Structure and perform a code check in RSA.
    regards
    Pawel Piechnik
    Autodesk, Structural Analysis Product Manager
    2010-01
    144
    Quote Originally Posted by pap View Post
    Hi,
    regards
    Thanks for the information.
  1. RC column reinforcement
    By njjsousa896918 in forum Robot Structural Analysis
    Last Post: 2011-10-14, 02:23 PM
  2. Concrete column with Rigid Reinforcement
    By pascal.bogdan in forum Robot Structural Analysis
    Last Post: 2010-06-16, 07:32 AM
  3. Column Strips, Middle Strips, & Reinforcement
    By kate.morrical61357 in forum Revit Structure - General
    Last Post: 2007-10-25, 08:04 AM
  4. Replies: 0
    Last Post: 2005-11-23, 01:22 PM
  5. Column Heights Change (was...Could someone check this)
    By Alek Sutulov in forum Revit Architecture - General
    Last Post: 2004-02-07, 02:32 PM
