Thread: Line length
    Member Devil's Avatar
    2009-09
    Riga, Latvia
    26
    Default Line length
    Hello.. Is possible lines put in one layer, and get the lines total length?!
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    621
    Default Re: Line length
    Two lisp files attached (not mine), this is asked often so search on here for other solutions.
    Active Member rvpas2000's Avatar
    2002-05
    VILLEURBANNE - nearest of LYON- France
    84
    Hi devil and richard,
    You can use EXTRACT DATA
    Insert tab/linking & extraction panel and select extract data
    Just follow assitante
    1st-create a new data extraction-->next
    2nd-give a file name-->next
    3rd-select data source-->next
    4th-select the objects want to extract (example line)-->next
    5th-uncheck properties you dont need and leave only lenght-->next
    6th-uncheck show name column, show count column
    7th-right click on lenght name column
    8th-choose insert total footer and sum-->next
    9th-choose where you create table-->next
    10th-choose table style-->next
    11th-finish
    Bye
    Pascal
    2009-09
    Riga, Latvia
    26
    Oh.. yes. Thanks. I forgot that is command Data extraction.
    And I look in other forum, and found LISP file.
    Type: appload.. find this file, click load
    then in command line type: lencal
    now I must understand how I can write my own lisp command...
    2009-09
    Riga, Latvia
    26
    Quote Originally Posted by Richard.Kent View Post
    this is better.!
    2002-05
    84
    Hi,
    your lisp is cool. !
    I forgot one thing, In EXTRACT DATA at stage 6th you can use filter column to extract for example, lenght of pipe of water, electricity etc...
    Bye
    Pascal
  1. Zero length line
    By smooth shoes in forum AutoCAD General
    Last Post: 2007-11-12, 11:19 AM
  2. Lisp routine to list line length and line ID
    By hlecates in forum AutoLISP
    Last Post: 2007-03-21, 04:03 PM
  3. How to get length of line
    By avinash00002002 in forum AutoLISP
    Last Post: 2006-05-23, 01:04 PM
  4. Specifying line length
    By peter.gilson in forum AutoCAD LT - General
    Last Post: 2005-06-02, 04:14 PM
