Hello.. Is possible lines put in one layer, and get the lines total length?!
Two lisp files attached (not mine), this is asked often so search on here for other solutions.
Hi devil and richard,
You can use EXTRACT DATA
Insert tab/linking & extraction panel and select extract data
Just follow assitante
1st-create a new data extraction-->next
2nd-give a file name-->next
3rd-select data source-->next
4th-select the objects want to extract (example line)-->next
5th-uncheck properties you dont need and leave only lenght-->next
6th-uncheck show name column, show count column
7th-right click on lenght name column
8th-choose insert total footer and sum-->next
9th-choose where you create table-->next
10th-choose table style-->next
11th-finish
Bye
Pascal
Oh.. yes. Thanks. I forgot that is command Data extraction.
And I look in other forum, and found LISP file.
Type: appload.. find this file, click load
then in command line type: lencal
now I must understand how I can write my own lisp command...
Hi,
your lisp is cool. !
I forgot one thing, In EXTRACT DATA at stage 6th you can use filter column to extract for example, lenght of pipe of water, electricity etc...
Bye
Pascal
