Results 1 to 9 of 9
Thread: Variable for Hide Layout/Model tabs
    2007-11
    Pune
    28
    Question Variable for Hide Layout/Model tabs
    Hello All
    what is the variable for Hide Layout/Model tabs.
    (The option is available on context menu & in Options->Display->Layout Elements)
    Thanks
    Yogesh
    Houston
    9,351
    Default Re: Variable for Hide Layout/Model tabs
    It is not a system variable, but stored in the registry here:
    HKCU\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\[profile_name]\Drawing Window\ShowTabs
    You can control it at the command line like this:
    (setenv "ShowTabs" "1")
    (setenv "ShowTabs" "0")
    R.K. McSwain | CAD Panacea |
    2000-01
    Seattle WA USA
    5,857
    It is also set by workspaces in the CUI.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2010-02
    12
    Could someone be more specific about how to find it in the CUI. Somehow my tabs disappeared and I can't figure out how to get them back. The box is checked in options to show model and layout tabs. It's driving me nuts. Thanks.
    p.s. I also tried (setvar "Showtabs" "1"), didn't work.
    Cairo - no, not Illinois
    4,617
    setenv and setvar are _not_ the same thing
    Also, when you are using setenv to manipulate environment settings, case sensitivity matters -- SHOWTABS is not the same as ShowTabs or showtabs or Showtabs.
    Programming Moderator BlackBox's Avatar
    2009-11
    5,240
    Here's another way:
    (defun c:TABS  ()
      ;; © RenderMan 2011
      (vl-load-com)
      (if (= :vlax-true
             (vla-get-displaylayouttabs
               (cond (*prefsDisplay*)
                     ((setq *prefsDisplay*
                             (vla-get-display
                               (vla-get-preferences (vlax-get-acad-object))))))))
        (progn
          (vla-put-displaylayouttabs *prefsDisplay* :vlax-false)
          (prompt "\n** Layout tabs: Off ** "))
        (progn
          (vla-put-displaylayouttabs *prefsDisplay* :vlax-true)
          (prompt "\n** Layout tabs: On ** ")))
      (princ))
    [edit]
    Simplified version:
    (defun c:TABS ()
      ;; © RenderMan 2011
      (if (= "1" (getenv "ShowTabs"))
        (progn
        (progn
      (princ))
    [/edit]
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Houston
    9,351
    Quote Originally Posted by templedesignllc View Post
    That is because you used "setvar" not "setenv" and the string is case sensitive.
    Try again: (setenv "ShowTabs" "1")
    TN/KY Area
    1,636
    Quote Originally Posted by RenderMan View Post
    Here's another way:
    Simplified version:
    (defun c:TABS ()
      ;; © RenderMan 2011
        (progn
        (progn
      (princ))
    [/edit]
    Instead of the prompt I like
    (alert "Wax ON")
    or
    (alert "Wax OFF")
    The Karate Kid movie has been on all the past week.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2009-11
    5,240
    Quote Originally Posted by Jmurphy View Post
    (alert "Wax ON")
    or
    (alert "Wax OFF")
    (defun c:FOO (/ onOff)
      (initget 1 "ON OFF")
      (if (= "ON" (setq onOff (getkword "\n\"Wax On\", or \"Wax Off\"? [On/oFf]: ")))
        (command "._browser" "http://mhs9192.com/clipart/80s%20chi...0WAX%20OFF.jpg")
        (command "._browser" "http://www.yourkloset.com/wp-content...gin-Waxing.jpg"))
      (princ))
  1. Hide Layout Tabs
    By Robert.Hall in forum AutoCAD General
    Last Post: 2007-09-24, 01:07 PM
  2. Add Right Click Menu to Hidden Model/Layout Tabs
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2007-09-21, 07:40 AM
  3. Hide Layout/Model tabs in every drawing
    Last Post: 2007-06-19, 02:11 PM
  4. Model / Layout tabs are missing
    By stephen.coff in forum AutoCAD General
    Last Post: 2007-06-14, 06:07 AM
  5. Replies: 2
    Last Post: 2006-07-27, 04:39 AM
