Summary: A Notes Tab in the Sheet Set Manager to list all of the notes referenced in a Sheet Set.
Description: I would like a "Sheet Notes" tab as part of the Sheet Set Manager. The Notes tab should list all the notes that the user wants to be referenced on the particular sheet(s), with numbering/lettering of paragraphs/sub-paragraphs formats available for modification, as well as automatic/manual/continued/renumbering options.
This would make notes and/or their numbering available for reference via fields to all sheets within a sheet set.
The notes tab should also list notes that point to another referenced note (if so desired).
This would help to see what sheet(s) a note is referenced on w/o opening the sheet(s).
There should be an option for import/export of notes from/to other formats (*.doc, *.csv, *.odt, *.ods, etc...)
How Used: The addition of "Sheet Notes" to the sheet set manager would greatly simplify note referencing in a sheet set.
Often there are notes such as, "...see note X on sheet Y...", or whole note paragraphs are repeated on several sheets.
Updated referenced notes via the sheet set manager would a huge benefit those who use sheet set manager.
No longer will one have to search and open all the plans for notes that reference a note that had been changed.
Feature Affinity: Sheet Set Manager
Submitted By: Nathan Selles-Alvarez on August 31, 2009
