Thread: Revit MEP 2011 Copy/Monitor not working?
    2008-08
    52
    Default Revit MEP 2011 Copy/Monitor not working?
    When we copy/monitored light fixtures in our MEP model and the fixtures were moved in the architectural link, we were not able to move our fixtures. In the coordination dialog, I was only given the option to Accept Difference or Reject. Shouldn’t we be able to move the MEP fixture to be coordinated with the architectural fixture? Otherwise, we would have to copy the fixture again and it would be too much duplication of work.
    Is this maybe a glitch that will be fixed with the service pack?
    Thanks!
    -Jess
    Question Re: Revit MEP 2011 Copy/Monitor not working?
    I'm having the same problem, it looks like none of the features of the Fixture copy/monitor are working. Its not really following the changes being made. There is no option to move the fixtures to the new position, and it looks like if you post pone or ignore, the list is wiped clear so the changes are no longer tracked.
    I would think this is one of the major new features for getting MEP to work better with Architecture, and it doesn't work at all.
  1. MEP 2011 Copy/Monitor Fixtures
    By asc in forum Revit MEP - General
    Last Post: 2011-11-09, 10:37 PM
  2. 2011: Copy/monitor multiple not working... Any ideas?
    By kyle983581 in forum Revit MEP - General
    Last Post: 2011-10-26, 08:51 PM
  3. Copy/Monitor Lights flipped - 2011
    By polk.rob in forum Revit MEP - General
    Last Post: 2010-11-26, 08:11 AM
  4. 2011 - Copy / Monitor - Odd Type Behavior
    By saeborne in forum Revit Architecture - General
    Last Post: 2010-10-13, 07:48 PM
  5. Copy/Monitor Arch Walls Not Aligned 2011
    By myBIMhero in forum Revit Structure - General
    Last Post: 2010-07-20, 07:47 PM
