Alfredo Medina
Unfortunately, there is no link between rooms and ceilings. Since that is not possible yet, we have to do some workarounds. Below is an example: (see illustration)
Schedule # 1 is a Room schedule. It contains Room #, Room Name, Ceiling Height, (taken from the room's Limit Offset parameter, but not linked to the ceiling element), and the Finish Key. (This field will be available after creating schedule 2)
Schedule # 2 is a key schedule of Room elements.
The key parameter is Finish Key. Then you add Base Finish, Floor Finish, Wall Finish, and, instead of Ceiling Finish, there is Ceiling Key, since you want to show more information about your ceilings in another schedule. The values of this Ceiling Key column are added manually, after you do schedule 3.
Schedule # 3 is a ceiling schedule.
The value of Keynote is taken from the ceiling type's keynote parameter. Then, we have Type, Manufacturer, Assembly Code, etc.
