Thread: google earth connection - globe link vs google earth extension
    2004-12
    21
    Default google earth connection - globe link vs google earth extension
    while exporting revit models to google earth via globe link, I discovered a strange behaviour when the target aerea is not flat. (pic_1)
    this is caused by the "relative to ground methode" used in the exporter to calculate the geometry z-coordinate.
    looks like deconstructivism, but I guess this is not the intention of the inventor.
    exporting through autocad's google earth extension (labs.autodesk.com) keeps the model upright. (pic_2)
    this methode uses an enapsulated collada file.
    but with this approach you don't have access to the materials of the model inside google earth anymore.
    hopefully a combination with the best of both exporters will make it soon into revit.
    -rpict
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: google earth connection - globe link vs google earth extension
    Yes, I too have noticed this. Can you explain how you used Autocads to export it correctly?
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2004-12
    21
    1) from revit export the model as fbx
    2) in autocad -> importfbx
    3) then -> publishkml
    -rpict
    Member vennix.239720's Avatar
    2010-01
    Leende, the Netherlands
    12
    Building on the matterhorn?
    beware the wrath of Reinhold Messner!
    http://www.youtube.com/watch?v=dKvrwehK0H4
    Geert
    Geert Vennix
    architect
    www.geertvennix.nl
  1. how to keep render appearance in globe link / google Earth!?
    By nso in forum Revit Architecture - General
    Last Post: 2011-03-08, 08:34 AM
  2. Globe Link - Google Earth Acquire Scale Off
    By bwiab in forum Revit Architecture - General
    Last Post: 2010-02-04, 08:22 PM
  3. Situating Model in Google Earth with Globe Link
    By jmarchese in forum Revit Architecture - General
    Last Post: 2009-08-10, 08:39 PM
  4. Revit Google Earth - Globe Link
    By rrijswijk.104343 in forum Revit Architecture - General
    Last Post: 2008-10-21, 03:45 PM
