Thread: Callout line pattern/style
    2004-11
    6
    Default Callout line pattern/style
    Hi,
    Both Revit 6.1 and Revit 7.0 (build 20041113_2030) have a Help topic called "Creating the Callout View". It shows a screen capture of a callout bubble with a dot-dash line pattern, with a solid line leading to the callout head/tag.
    However when using the callout tool in both these versions of Revit, the callout bubble's line pattern is solid (continuous). Is there any way of specifying the callout bubble's line pattern/style? i.e the line pattern for the box with rounded corners, not the callout head.
    Cheers,
    Jason.
    2004-06
    Cairns, Australia
    136
    Default Re: Callout line pattern/style
    Go to Settings> Object Styles. You can change the Callout Boundary line pattern in the Annotation Objects tab.
    2004-11
    6
    Problem resolved, the method is obvious now. Thanks.
  1. I wish I could create custom line patterns with symbol/letters in the line pattern.
    Last Post: 2010-11-13, 12:43 AM
  2. Only one plan callout style possible? What's up with that?
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2009-02-15, 03:33 AM
  3. Unable to change Feature line, Line style
    By m.vanitallie in forum AutoCAD Civil 3D - Grading
    Last Post: 2008-03-20, 01:46 PM
  4. Single Line Pipe Style to Double Line Pipe Style Clean Up
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-01-22, 04:44 PM
  5. Custom Line Style Manager to Simplify Line Style Creation
    Last Post: 2008-01-09, 09:21 PM
