Results 1 to 1 of 1
Thread: Comp Owner Problem
    2003-12
    7
    Cool Comp Owner Problem
    as = amiGetContainingComp(pGeomKey, pLeafCompKey);
    as = amiGetContainingComp(pLeafCompKey, pContCompKey);
    as = amiGetCompDef(pContCompKey, pTargetCompDefKey);
    as = amiGetCompOwner(pLeafCompKey, pTestCompDefKey);
    as = amiAreKeysEquivalent(pTestCompDefKey, pTargetCompDefKey, bRetValue);
    if(bRetValue==Adesk::kFalse){
    	as = amiGetCompDefName(pTargetCompDefKey, pTargetCompDefName, Adesk::kFalse);
    	as = amiGetCompDefName(pTestCompDefKey, pTestCompDefName, Adesk::kFalse);
    	acutPrintf(_T("\nKeys Are: %s, %s"), pTargetCompDefName, pTestCompDefName);}
    as = amiIsCompDefLeafNode(pTestCompDefKey, bRetValue0);
    as = amiIsCompDefLeafNode(pTargetCompDefKey, bRetValue);
    if(bRetValue!=bRetValue0) acutPrintf(_T("\nDef Keys differ in type: %d, %d"), bRetValue0,  bRetValue);
    By running above piece of code one will very easily see that pTargetCompDefKey and pTestCompDefKey constructed by appropriate APIs are NOT equivalent, although they refer to the same object. The difference is “type mismatch”: pTargetCompDefKey is leaf-node definition, while pTestCompDefKey is NOT! I don’t know if it was AutoDesk intent, but you should take into account this “glitch”.
  1. Why is my new comp so slow?
    By ECRUEY in forum CAD Management - General
    Last Post: 2010-05-19, 10:28 PM
  2. having comp issues
    By KGC in forum Hardware
    Last Post: 2008-03-11, 05:23 PM
  3. The Operation Comp... acdcsymbols.arx
    By BinnsBarry in forum AutoCAD LT - General
    Last Post: 2007-12-18, 01:34 PM
  4. DWF COMP. 2 W/REVIT 9.1
    Last Post: 2007-01-13, 05:18 PM
